Old 06-29-2010, 05:36 PM   #1
JerryLH3
JerryLH3's Avatar
JerryLH3 is on a distinguished road
Very nice. I'm in the process of restoring my Turbo, and being that I'm doing bodywork and repaint on the exterior, I keep debating on pulling the engine and respraying the engine bay at the same time. In my case, space is the major issue, as I'd have to do some serious garage reorganizing. I'd probably also have to move things inside the house and keep them there. I'm pretty sure my girlfriend wouldn't be too keen on that.
Jerry
1991 Mazda RX-7 Turbo - the current project/money pit
JerryLH3 is offline   Reply With Quote
Old 06-29-2010, 07:42 PM   #2
need RX7
Clean S4 Nutswinger
need RX7's Avatar
How much stuff is on the interior side of the harness that comes through the driver's side of the engine bay? I'm debating whether or not I should pull it out when I paint my engine bay. Is it even feasible without removing the dash?
Old 06-30-2010, 12:17 AM   #3
no it's not.
If you go in, then GO IN!
Pull the dash, pull the HVAC, pull the pedal box, the rack, EVERYTHING!
Cause once you start, might as well do it all, or not even bother trying.
Mind you, if you're only doing spot painting and keeping the bay the same color, then there's no point... but if you are completely changing color like me, then it's worth it.
dude, brian right?
After I get the car painted, and buy all the clips, bolts, and etc to put it all back together, I still need:
NEW TII driveshaft
BNR Turbo Rebuild
Coilovers
Wheels
Tires
stereo
speakers
And that's just the big stuff.
Along the way I might pick up some stuff like new carpet, floor mats, door seals, etc.... so $380 saved on paint is a BIG deal.
Old 06-29-2010, 08:01 PM   #4
budget? What is this thing you speak of
Budget's and hobbies don't mix well I've found
Old 08-12-2010, 01:27 PM   #5
FC3S Murray
frustrated!
FC3S Murray's Avatar
.........yeah tell me about it
Same pig, new soul
Old 08-12-2010, 01:37 PM   #6
Silver86
now what?
Silver86's Avatar
Silver86 is on a distinguished road
tell that to my wife
1986 Rx7 coupe - arctic silver - sold
aka - 20bforme
Silver86 is offline   Reply With Quote
Old 06-30-2010, 06:18 AM   #7
Yeah, and if you had waited a little while longer before you bought the paint, you could have the color that you wanted, not the color that you settled on. It's not like you held off buying a set of wheels that you can bolt on later, you made a decision that is not easily reversible. I would've waited until you could've afforded the color that you were most happy with.
Old 07-02-2010, 10:33 PM   #8
Dude, I still got BMW M3 Alpine white... settled? Hardly. The pearl was a college student's baller pipe dream anyway. Besides, sometimes, with time and money constraints, you gotta have some give-n-take or you will never get shit done. I learned this the hard way. =)
Anyway, on to my update:
Got my Pineapple Racing engine-stand adaptor, OMP rebuild kit, and some other loose ends.
I degreased the left side of the block real quick because it's a to do it when it's bolted to the stand.
Old 07-03-2010, 05:04 PM   #9
Painted the bay this morning
Old 07-10-2010, 08:54 PM   #10
Started working on the dent in the rear quarter... After the engine bay, it was the second worst part of the car. Got most of it out, but still have a bit to go.
Old 07-10-2010, 08:56 PM   #11
some more pics:
Not perfect, but for 3 hours of work, it's a hell of a lot better than when I started. The S5 molding now at least somewhat fits flat.
Old 07-17-2010, 08:48 PM   #12
Well, I got the quarter back out pretty well... spent a lot of time on it...
I sanded off all the paint, then hammered out as much as I could, followed with some stud welding and a lot of pulling. After that hammered the metal, and ground down some of the pitting left from the stud welder.
At the shop, we had this 3M Fiberglass reinforced body filler, made for thick applications and shaping panels back in place. Unlike Kitty hair, and other glass fiber body fillers, this stuff is top notch! The strands are chopped so fine you cant even see them, it applies easy, hardens like concrete, and stays flexible enough to avoid trouble. If I ever recomended a filler, this stuff would be it!
Anyway, so, we did a nice thick coat, let it set, and then used a 12" grinder pad on it to shape the filler somewhat. there were some low spots, so we went for another coat.
The next day, I used the grinder to cut into the filler a bit, and then used an air sander (the reciprocating long board type) to sand the panel straight.
Now, this is where I am right now, and it's damn near perfect already. On monday, I'll add a bit more 3M stuff on the bottom section near the trim, but otherwise the panel is ready for some convetional filler (imperfections n stuff) and a coat of paint!
I wont have the time to spray the whole car body color, but at least I got the quarter and the engine bay done... These were the two hardest things, and the worst cosmetically.
Anyway, here are the pics of the somewhat finished progress:
Old 07-22-2010, 06:19 PM   #13
And.... surprise!
I ran out of time. So, I guess stripping down a car, and completely painting it in just 10 4 hour work days was a bit unrealistic... even if I DID strip it outside of class.
I'm glad I got the two worst areas done though, the engine bay will never need another paint job again as long as I own the car, and the dent in the quarter would have probably cost me somewhere like $1500 to fix at a body shop.... Now that that's done I can reinstall the engine, and get the car running again so I can enjoy the rest of the warm weather.
EDIT: I found out that they ARE going to hold a Saturday hobbyist class during the fall semester. I think I'll sign up for it and get the car running in the meantime.
Old 08-12-2010, 08:56 AM   #14
TeckniX
TeckniX is on a distinguished road
That rear quarter looks pretty good! Did you use the bondo-glass product to get all the imperfections out?
Also how did you manage to get the line of the body above the wheel well to be nice and true?
TeckniX is offline   Reply With Quote
Old 08-15-2010, 01:16 AM   #15
Hell nah, I used some ultra mega crazy 3M shit! I DID hammer and pull the dent out as much as I possibly could though, so it's not as thick as you might imagine... What we did was to pull the part under the line out first, and then go back and pull out the part above the line. After that, caved and paved the 3M stuff on, and used a wide sanding disk on a big orbital grinder to shape the panel.
Went over this with 3M again, and after that, used a long bladed air sander to shape it into what you see there. Now, after this, the panel still needs just a real thin layer of bondo and glazing putty to make it perfect, but the fiberglass shit took care of mostly everything really. Honestly, the hardest part was to shape the dip for the rear trim piece, that area got distorted really bad.
Also, having instructors with 20+ years experience helps too.
Anyway, after letting the car sit for a while, I finally got around to ordering more stuff and started installing the polyurethane bushings... so far I got the front control arms done.
I think I found mecca btw, and it's called Himni Racing!
They are the ONLY place I found a full ss harware kit for my engine, as well as a samco interooler hose kit to replace the stock FC hoses, and a greddy bov adaptor. Usually, to run a greddy bov, you need to buy a $150 cast pipe, or weld in a flange. Himni sell a flange that just clamps right on to the stock hose, genius! (this way I can go back to stock Bov if I sell the car or if I have any problems.
PS: Also ordered like $250 more worth of gaskets, seals, and orings from Mazdatrix, I swear, by this time, it would have been cheaper to just get an entire fucking rebuild kit.... damn. Got an OMP rebuild kit from Pineapple racing as well while I'm in here.
Pics of all this being installed will be up within the month cause I'm trying to finish my car for a drift comp at the end of the month.
