Old 10-10-2009, 09:43 PM   #24
Found the answer to one of my problems - the Charge Relief Valve was setup improperly - entirely my fault. 7 keystrokes on the Motec and the problem was solved, figuring it out though was an entirely different problem. Inj 7 is the CRV, notice in the second screenshot above the duty cycle is 0%, the one below it is 100%. 100% shows the valve boost and it stays closed, 0% shows it vac and it is held wide open. So in otherwords the turbos spooled slower than they should've, vented a significant amount to atmosphere, still made 11.5 lbs of MAP and 360 RWHP. Tonight I took a little trip and datalogged a 3rd gear pull. Note the boost level and more importantly the Inj #5 duty cycle. Inj5 being the WG. So, onto the fuel clogging and then back to the dyno.
