Old 10-09-2009, 11:29 PM   #1
Redhawkjrt
Brake, Turn, Go! Repeat.
Redhawkjrt is on a distinguished road
NHTSA RX-8 clutch pedal failure investigation
From Autoblog.com:
"Mazda's RX-8 sportscar is under the watchful eye of NHTSA for a problem that could effect far fewer vehicles but the problem is equally serious. The safety administration has reportedly received 40 complaints of 2004-2008 models that have experienced clutch pedal bracket failure, and in 15 cases, the rotary-powered Mazda was moving and the drivers couldn't change gears normally as a result. Two of those drivers could have found themselves in a more dangerous situation, as the clutch pedal was reported to have become wedged under the brake pedal.
At this point, NHTSA is just beginning to investigate these issues, and if a recall results in either case, the government agency will assuredly issue notice."
It would be nice if there was a redesign - recall on these; on the other hand, it would definitely not be nice to have this problem at the wrong time, like, say, on the Dragon!!!!
Redhawkjrt is offline   Reply With Quote
