Old 10-06-2009, 02:47 PM   #3
hcDave
hcDave is on a distinguished road
Hi Phoenix,
I do have an underbelly tray - but the cover that helps to divert air into the air intake (right hand side looking at the vehicle, right in front of the intake) is missing - I have put in some cardboard (temporary fix)
Rodding out a radiator is the process of removing the radiator tanks and pushing rods through the radiator core to clean it.
I talked with a mechanic at Mazda the other day and he said that without the kit it's next to impossible to get the air out of the system. He could not find the notice in his book though, and was quite busy, so suggested I try to find info about it online...
I just went out to check if there was any sweet white smoke when I started it and there wasn't any - do I have to wait until morning? (the car had been sitting for a couple of hours) I also noticed that the coolant level in the reservoir had returned to normal (I will edit that in my original post)
The fan seems to be turning fine, and I do still have the stock shroud.
Some good news (I hope) is that it has never overheated to the point of boiling over (it did get to about 3/4 of the way though once while I was going over a mountain pass) but I have always pulled over and toped off the coolant as soon as it indicates that it is low. (I hope this does not mean that it is pressurizing due to something other than air trapped in the system)
Thanks again for your assistance!
Dave.
hcDave is offline   Reply With Quote
air, coolant, overflow, rebuild, seal
