#11 |
Rep Power: 10 ![]() |
LOVE EM
Just really REALLY take your time mounting them up as you only get one chance to cut a hole that big in your hood. You can see where I mounted mine. I started by taping off the area where I wanted to mount them and measuring out where the center line would be. Measured where the pin would come throug, lined it up with the support and made a mark. Measured the distance tot he the top, the bottom, did some math based on the diameter of the the two rounds, drew them up triple checked everything and then used two different hole saws for the top and bottom and a cut-off wheel to cut out the remaining. You'll have to trim the supports on the underside of the hood to be able to get to the nuts. Make sure you get the locking kind. I've come out to my car in the past to find the alarm tripped and one of the latches was attempted to be opened. I love them, absolutely love them. I've heard alot of people talk poorly of them, then I come to find out they installed them in 20 minutes as opposed to the probably 4 hours that I spent. In other words, in-correct installation will result in sucky latches.
