Old 09-09-2009, 11:47 PM   #4
maybe twas because of the KOYO's higher capacity, but once I burped the system with the bleed screw on the upper radiator hose inlet, I didn't have a problem with it. MY biggest problem was mounting and getting it to bolt in, not air bubbles like I thought it would be.
A good trick is to take of the hose going to the Throttle Body from the rear iron, that lets the system expell most of the air and fill up better w/o having to burp the coolant as much.
