#11 |
Can't.Make.Up.My.Mind.
ok so i think i may have found some s5 irons a friend of mine has here. should be able to pick them up for about 150 bucks, then ill clean them and lap them and have them ported. im curious if i can use a s4 front iron though instead because i think i would rather use the mech. omp instead of the 1500 dollar electrical one. i am for sure gonna buy new housings and im debating if i want to use the s4 turbo rotors or if i also want to buy the s6 rotors my friend has too. i know i wont be able to run as much boost on pump gas without messing with timing( advice from murray if i understood correctly) but they are local which makes things alot easier on me as far as money and availability obviously. he wants 250 for the rotors? and suggestions are welcome.
'90 GTUs Stay up to date with my photography '06 Toyota Highlander Hybrid '10 Toyota Prius "Initial Success or Total Failure" |
