Old 07-31-2009, 07:07 AM   #11
FC3S Murray
frustrated!
FC3S Murray's Avatar
Did the clearances get worse as time went on?? Beer >= Rotor Clearancing
haha...actually, I started worse and got into the "zone" when my buzz kicked in. The constant sound of grind..grind..grind on the stone was hypnotizing yet soothing
Quick question guys, I was told it would be wise to order a few different size spacers for the front assembly stack just incase my freeplay is larger then factory spec. I have the K spacer right now BUT mazdatrix doesn't even show the K spacer not to mention all the letter spacers are for the 3rd gen front end? HMM?
Also, what do you consider a bad thrust washer plate? I have a small spot on the thrust plate that shows maybe 4 small thrust bearing indents fron the needle bearings. Not deep by any means but Mazdatrix recommends replacing the bearings, washer plate and main bearing plate. My main bearing plate looks fine with no "notches".
Same pig, new soul
