Old 01-21-2015, 02:02 PM   #1
chibikougan
chibikougan's Avatar
No if they are bad they will heat the lugnuts enough to burn yer fingers.
To change the bearing you will have to Notch as per Mazdatrix instuctions.
Old 01-21-2015, 07:30 PM   #2
project86
Can't.Make.Up.My.Mind.
project86's Avatar
I need cheap 5 lug wheels...
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 01-21-2015, 08:37 PM   #3
I actually have a set of 5-star wheels with good tires if you're seriously interested.... last time I had to ship a set of wheels/tires it was like $30 each... lemme know if you want pics...
215/40/17 I THINK... I have a ton of pics from when they were on ebizzle and craigslooser...
Old 01-21-2015, 08:40 PM   #4
project86
project86's Avatar
ya man post some pics. I just need a set for the hub swap like i said. I don't have any 5 lug wheels. I though i had some at my parents place but they say they aren't there...
'90 GTUs
'10 Toyota Prius
Old 01-21-2015, 07:44 PM   #5
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
If you're passing through the middle of Kansas I have a set of ratty old sawblades off an 87 GXL you can have for free. Cheap enough?
Shipping them wouldn't be worth it, they're not very nice, but they are cheap.
Old 01-21-2015, 08:08 PM   #6
project86
project86's Avatar
Cheap enough yes haha. but I don't find myself in Kansas often. Im not particularly worried about how nice they are. I just need something cheap for using after i swap my hubs. Im looking on the internets for steel wheels at the moment
'90 GTUs
'10 Toyota Prius
Old 01-21-2015, 08:48 PM   #7
project86
project86's Avatar
On another note... does anyone make an aftermarket solution to the front ball joints that connect to the hub? I need to replace my sad factory ones.
'90 GTUs
'10 Toyota Prius
Old 01-21-2015, 09:00 PM   #8
GySgtFrank
GySgtFrank's Avatar
One of the folks in St. Louis is working on some. He posted this on the STL RX Club facebook page. It sounds like they're still trying to work out the bugs with manufacturing and testing. It looks like it uses a common press-in ball joint.
https://scontent-a-dfw.xx.fbcdn.net/...61&oe=552944FC
Stu Kelly
Meeting Monday for a partnership with a new CNC shop to help bring these joints to you all sooner. Our original CNC shop was a relationship with broken promises, so I apologize to all who were waiting for these products. Thank you for your support and patience, sorry this has taken so long.
Once we have sets of each version made we will be taking applications for testers to get their hands on these before anyone else. We will announce when testing will start and more info on how to become a tester. Lets plan on this announcement for the end of January early February
We will be offering three versions of these joints and each version will help to correct roll center.
These ball joints are for the Series 4 Rx7 FC but can be used on Series 5 control arm with some cutting and drilling.
The pricing of these joints will be around $300 and will include new ball joints, mounting bolts, and have the ball joints already pressed in plug and play style.
Here are the details of each version.
Version 1 will have slots allowing for incremental extensions up to 1.5" fully extended.
Version 2 will have fixed holes for stock positioning and 1.5" extended positioning.
Version 3 (for an additional price) will be fixed holes at any extension amount you would like up to 2.0" extended. For example a joint extended approx 1.675" from factory.
The picture is of Version 1 with slots and Version 2 with stock 1.5" extended holes.
Old 01-21-2015, 09:02 PM   #9
project86
project86's Avatar
One of the folks in St. Louis is working on some. He posted this on the STL RX Club facebook page. It sounds like they're still trying to work out the bugs with manufacturing and testing. It looks like it uses a common screw-in ball joint.
Stu Kelly
Those look pretty nice. I missing why i would need to extend them though?
'90 GTUs
'10 Toyota Prius
Old 01-21-2015, 09:07 PM   #10
GySgtFrank
GySgtFrank's Avatar
I think that part is mainly for the drifter crowd to get lots of negative camber. If they accept stock positioning they should work. I believe MazdaTrix also sells the stock replacement arms with the ball joints already pressed in.
Old 01-21-2015, 09:09 PM   #11
project86
project86's Avatar
they do indeed.. for $77 a side. Ill probably be ordering them soon. I need to clean up the hubs first too. I wanna get all the front end stuff taken care of while i have the front of the car up on stands.
'90 GTUs
'10 Toyota Prius
Old 01-22-2015, 08:34 PM   #12
project86
project86's Avatar
Im thinking of sending my single piston calipers in to mazdatrix as cores and getting rebuilt 4 piston ones. Sending in cores makes the price for the rebuilds about $128 per side. Do you think thats worth it or would i be better off getting a good used set of 4pist calipers and getting a rebuild kit? I guess more clearly what I'm asking is do you think mazdatrix is just taking old calipers and doing the rebuild kit for you or are you getting more than that for the price?
'90 GTUs
'10 Toyota Prius
Old 01-22-2015, 09:18 PM   #13
Last time I got calipers they were $35 each from a local jobber
Old 01-22-2015, 09:25 PM   #14
project86
project86's Avatar
well if you know where i can get calipers for $35 I'm all in. I don't think the price from them is too bad though. Plus they will most likely be clean and nice looking which save me the headache of having to do it lol
'90 GTUs
'10 Toyota Prius
Old 01-22-2015, 09:57 PM   #15
Napa dude...
