Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Black Halo Racing
Black Halo Racing (AZ) RX8 Aftermarket parts developer/distributer providing performance solutions. www.blackhaloracing.com 248-722-1275
Old 06-16-2009, 02:11 AM   #5
Flashwing
Flashwing is on a distinguished road
So, with the pictures out there I wanted to address a couple things which I've been getting questions about...
I've had some people asking me about pre-silencers and things along that nature. This is not, I repeat, not a dual resonated mid-pipe. One of the unique aspects is we have been able to produce a great tone without resorting to a dual resonated mid-pipe. There are two major advantages to this design.
First, we are able to produce a pipe which is lighter than other dual resonated versions. We're in the process of having the pipe weighed for comparison. The other aspect is the resonator doesn't contain any glass or steel wool packing which could blow out due to the excessive EGT's produced by the rotary. Having no packing means there's no risk of the pipe's sound changing over the life of it's use.
Ditching your cat has a few benefits. First, freeing up some restriction in the exhaust system means more air out. This can translate into a very slight power gain. The real gains are realized with custom tuning where you can run leaner Air/fuel mixtures and not have to worry about cat life. Second, you can pre-mix and run higher OMP injection without fear of clogging a cat.
Finally, a single resonator means no issues with fitting the pipe. This pipe will fit both automatic and manual transmissions. You also get all the mounting hardware necessary including OEM gaskets.
If you're looking for a mid-pipe that will not get you stopped for a loud exhaust or annoy your friends/neighbors with raspy sound this is the pipe for you. This will be the last mid-pipe you will ever have to buy for the RX8. The pipe is of superior quality and is produced locally here in Phoenix Arizona by a shop which specializes in custom one off headers for most of the major funny car and high HP dragster teams that are out there.
Black Halo Racing - We don't sell parts, we solve problems!
Flashwing is offline   Reply With Quote
