Old 05-18-2009, 01:41 PM   #5
Duffman692002
Member of the D club
Duffman692002's Avatar
Duffman692002 is on a distinguished road
Originally Posted by 3rd and final 7 View Post
i looked at the wiring diagram and it shows goes from the alt to connector x-07 which is the yellow plug on the other side of the engine bay just where the wwiring goes in the firewall then 1 branches to the choke and check relay which branches off 1 more time b4 it gets to the relay, one goes to a fuse which in one dicretion goes to anther fuse for the kick down switch which i belive is for a A/T, in the other direction it goes to the ignition switch. thats all it shows you can go to http://foxed.ca/foxed/index.php?page=rx7manual#firstgen and D/L the manual to your pc you going to be looking for page 50-10 or pdf pg 10
Thanks 3rd and final 7, that's actually the FSM I've been using. According to the FSM the -> symbol is the one for DIODE and if it's the choke/check relay that's causing me to have this issue, I could just put a diode inline with the WB wire and that would keep it from runnin with the ignition in the OFF position no? This is the first time I've done any major electrical work so if I come off as a bit dull, that's why.
Duffman692002 is offline   Reply With Quote
