Try some starting fluid... That is how I got the 4-port lit. Once it is running, you should be good to go (assuming you have a decent tune).
I discovered that the priming pulse that was required for a fresh rebuild is insanely long relative to a broken-in engine. Even if the timing is off 90 degrees, you should still get some fire out of the intake or exhaust. Did you check spark with an inductive timing light? Spraying the starting fluid will indicate whether it is a fuel or spark issue (if it starts on ether, it is fuel related. If not, spark related.)
