Old 04-26-2009, 10:37 PM   #16
bbade
bbade's Avatar
Sounds like you have a more serious issue, but I had the same problem. It turned out to be the clutch sensor. Use the PFC sensor screen and watch the signals coming in, if the clutch signal comes in as the pedal is depressed your sensor should be fine. The plastic rod on the end of mine had worn down, hopefully its not actually the engine!
