| Rotary Extreme www.rotaryextreme.com (CA) Rotary Extreme is back, still offering the same high quality products |
i like spinners
I have located everything to re-make it. But I need to put one togther on my own first before I re-release it to make sure it has everything. Also it will be the same as before. You will have to pr-heat the lexan to get it to form to the housing, That way it matches the lines. This is something that I am thinking of doing so that the customers do not have to.
The ingenious and decidedly weird Wankel rotary engine works by using internal combustion to bounce a fat metal triangle around inside a hollow metal kidney bean, which hula-hoops around a central shaft to generate power.--- Jalopnik www.rotaryextreme.com, after more then a 2 year break, Rotary Extreme Re-opens 9/11/08. |
