#1 | |
Rep Power: 20 ![]() |
Blue Blur
Oh lol, well my gauge registered at 19, i just assumed it was psi lol and it got to 7 pounds of boost, also there was a check valve installed in the line that went to the pressure sensor. I cant find that in any diagram so i removed it and it seemed to run a little better
#3 | |
flooding on hot starts is a VERY common problem for us.
19 vac and 7 boost is pretty good so far. Check your injectors to make sure some asshat didn't throw in some larger injectors without calibrating anything for them. Also, does it still lose power at 6k still? Last edited by Boostmaniac; 04-16-2009 at 07:05 PM. |
I had a similar leak, turned out to be broken exhaust studs.
Rough idle means what? It is hunting, brapping, to low? What RPM is your idle? Chances are high that you could benefit from a Rat's Nest removal and replacement of the remaining vacuum lines. Also, does your car still lose power at 6k RPM? Keep us updated. |
Blue Blur
no more power loss that i notice. Its just kinda stunmbles and misses a little thats all. I think its due too the exhaust leaking though. Other than that all i have left its fix the ebrake replace the bumper and bleed the brakes and its done. Oh i completely forgot i have to fix the driver window it goes down but not up
Blue Blur
UPDATE: gaskets are replaced, body is straight, still gotta fix brakes, bolt exhaust on, and make sure all my vac lines are were they are supposed to be, diagrams arent helping much. Had the same acorn problem again, i went straight to it this time, i cant for the life of me figure where this acorn came from
