#11 | |
Rep Power: 20 ![]() |
Today was a stainless steel line day. I was able to pick up the -10AN for the oil cooler and with some help get them all connected. I took some pictures so check 'em out. Around this same time I realized that my fuel lines are not -8AN but -6AN talk about bad luck. Hopefully Todd hasn't already welded the -8 bungs to the fuel rails, but if he did I don't think it will be too much trouble to just put on an adapter for -6. We'll see though. But here are some pictures: When I dropped in the engine: ![]() Notice the oil return flange. It's going to be a fun day when I actually can finally hook that up. ![]() The turbo with the V-Band adapter mounted to it with the V-Band flange waiting for welding. ![]() Prepping for figuring the turbo. My original intent was to mount the turbo very close to the stock location and just keep it as straight as possible. Didn't work out as you can see from the previous post. ![]() Oil Cooler Lines. That's a 120 on the top, a 90 on the side. -10AN line. Not bad for $70. ![]() ![]() Here's the beginning of my parallel fuel system. Should be feeding some 1200 cc/min and some 720 cc/min (I think, I'll have to double check the flow rates on the injectors). Should be enough fuel for my project. Anyone want to guess how much Horse power I'll make once I finally break the engine in and get it tuned? ![]() Backside of the engine. Simple 90 and shoots forward. It's actually a much cleaner install than the stock lines and I'm surprised I didn't do this sooner. ![]() Here's the oil cooler mounted and placed a few inches forward of the original position. If you look closely I cut out a portion of the angle iron to allow an additional inch of breathing room to the cooler. ![]() A better angle of the new lower oil cooler line.
