Old 04-06-2009, 01:40 PM   #11
cozmo kraemer
cozmo kraemer is on a distinguished road
Originally Posted by classicauto View Post
Well I got her fired up sunday. Couldn't run it long though as there's a random fuel leak in the center of one of my braided AN lines>>>?!???
It can be leaking up by the fitting and coming down between the steel and rubber in the line and then leaking through the SS braid at the lowest point. Hard to explain...
As long as it isn't a long run of SS line it is cheap so just take it out and replace it...should be simple enough right? In my LS1 build that was the only issue I had at initial start up, one of my AN to hardline adapter fittings was leaking so I had to REALLY torque it down. I really don't like AN fittings. The ones for my oil cooler seap a little also and they are tight, it is frustrating.
cozmo kraemer is offline   Reply With Quote
