Old 03-27-2009, 07:33 AM   #18
Originally Posted by Fidelity101 View Post
Made some progress today mostly just sand blasting and beginning painting for the intake manifolds and water pump housing:
I still have to put some more coats on, just some 5 dollar rattle can w/ ceramic so it may not hold heat out super well but worst case scenario it looks nice lol.
Be careful with that paint. I used the duplicolor hi-heat ceramic stuff, I don't know if it has to cure, didn't say anything on the can, but I was able to take it off with a passing brush of a choke-clean soaked rag. Needless to say I was dissapointed.
Sounds good. White is probably a better choice as you'll detect leaks easier. Everybody jumps to black because it masks stains better and is easy to spray flat from a can, lol.
Looking forward to the pics...
Only flat black though. If you're doing a full paint job, black tends to show all your sins
some updates, got some shit installed some other stuff painted and cleaned, port/gasket matched the intake manifold and I am almost done with the porting and polishing of the TB, it should be up and running in the car (with a white engine bay to match the painted white exterior) within a couple weeks.
but this is where the engine is now mostly all assembled....
MY CLOSET!
now I just needs motor/trans mounts, fluids, misc hose or two and my roommate to make me an RPM switch.
If you need some S4 parts, lemme know. I've got TONS and will let most of them go for shipping plus a few $.
