Old 11-20-2009, 09:42 AM   #1
What size injectors are you running at 90%?
Marren "American Style" 750/1000cc/min or 72/96 lb/hr injectors. I later found out that they are Delphi's and designed for propane Basically the spray pattern is more of a firehose than anything and they are NOT very linear. My only real saving grace is the Motec inj drivers being so damn powerful and so damn accurate. My belief is, not having seen many other cars, is that std or poor injectors, like these, combined with not the greates inj drivers, leads itself to a strange running car. If you look at some of my logs it becomes pretty clear when looking at duty cycle. But whatever. I've had a bunch of conversations with a few top people in the field and I may be doing some testing in the spring. FWIW, I may be redoing my fuel rails as well. I'm not going to bad mouth the guy on the forum, I think it's something personal between him and I and he still makes some cool products and his injector service is still adequate although I'll be going to Kinsler from now on
If all goes well, the engine should be rebuilt and in the car in March. I would like to get some base tuning done prior to DGRR (even though my FC wont be comign).
Cool, lemme know, I'll be out there sometime in March as well to pick up a few things from Dave - tranny and rear end more specifiacally. FC won't be there, or maybe it will, depends on timing.
I will be going to Dave's with the irons prior to the engine build though to discuss those fun ports he mentioned last time I was up there...
Say who in the what now? Fun ports? Details please....
I also was considering getting him to rebulid my trans and cryo some things, dunno though -we'll see how time/money permits...
He's rebuilding my 6-spd and cryo'ing it as well. I highly rec the cryo treatment. It's been proven 100's of times over, especially on his rotors and tranny's and e-shafts. Definately worth it in my eyes. It'll be nice if my tranny, that everyone is saying is weak and sloppy, can stand up to 2x renni torque and still last and shift silky smooth..... I gotta get back on that damn thing, taking up too much shop space. Hehehe, went to the Jersey Meet on Tuesday and had the same conversation that I always seem to have regarding that tranny, I wouldn't do it, it's weak, it breaks all the time. Yeah but when is it breaking? When is it blowing? The answer is, when there is 0 torque being applied to it. It's not a strength issue, it's a design flaw that has a TSB on it
Old 11-20-2009, 09:31 AM   #2
Oh - and I misbehaved and got some LS2 Yukon coils for my RX8... just need to install them....
I know, I know... stop spending time/money on the 8, lol....
Old 11-20-2009, 09:46 AM   #3
Yeah, you should. You should send them to me and start concentrating on the FC. It would be cool to be get the 8 on the dyno, make a pull with the stock coils, and then put the Yukon LS2 coils on and make a second pull, see if there is any apprechiable difference. I plan on doing that with my LS1 vs LS2 coils in the spring IFF I can build it such that it's an easy swap. I believe the connectors will plug right in. If that's the case, than it's a matter of swapping out the "pack" which shouldn't take that long. We'll see..... soo much to do!
Old 11-20-2009, 09:56 AM   #4
Thats high on a 1000cc inj for only 15lbs or less... crazy! I'm still plotting that side of my setup out. I'm sure I'll end up with 1300 or 1600 secondaries. Been contemplating running four secondaries though instead and two primaries... we'll see...
I'll discuss the "fun" ports when I get to that stage... its the big key difference between your engine build and mine and w/ Nismo's (Kevin?) as well.... we will all have uniquely different setups which will be cool to see the power curves. Peak power will probably be within 50hp or so of each other.
My trans was rebuilt about 12K miles ago, but nothing special. It shifts fine, but that was with a street ported S5 block and ported stock S5 turbo around 8psi... nothing crazy. I'd rather get the trans addressed while its out of the car then put it in only to have to take it back out. It is a jspec version as well, so no overdrive for me Maybe someday I'll venture down the 6spd path...
For the LS2 coils it wouldnt be a simple swap of the pack unfortunately since I have RB race wires which have a different boot connector than whats needed for the LS2. So I'd have to make a pull, swap the pack, pull the wheel and swap the wires - not hard, just an extra step involved. From the rx8 community the general belief is not much on power when your NA, but more about the clean burn and fuel efficiency which is really all I'm looking for and the reliability of them is an added bonus (and cost.. I only paid $20/each).
Old 11-20-2009, 11:01 PM   #5
Meh, not really, look at the power. I originally planned for 350-375 as a starting point and then upgrading if need be. I guess the need be is here. 90% is a little too high and I want to try a new injector. One with a better spray pattern, something a little more predictable and hopefully get my idle above .83-85L ... bleh
Uh huh.... uh huh.... I see
I'm going to corner the market for the 6-spd FC conversion if this all works out. It won't be all that cheap but it will bolt right in. Just need to address the speedo crap. Not an issue for me..... suckers
Honestly, I'd leave the tranny alone until you start to have problems with it..... JUST DON"T USE ROYAL PURPLE! That stuff blows. The Type R trans is good for some serious HP and torque before it becomes a weak point.
I see, I see. So even if you had a set of wires premade, you'd still have to pull a wheel to swap wires? That kinda.... sucks. Where in the hell did you find them for $20 each. more importantly, where are the 4 that you didn't get. 'Cuz I want them..... now.
Old 11-20-2009, 11:36 PM   #6
I have "connections" on domestic parts (too bad I dont build domestic cars)... long time drag race friend of mine builds GM stroker engines, etc etc blah blah...
I may just leave the trans for now... its still up in the air..
I really need to do an update to my thread and stop whoring yours out
Old 11-20-2009, 11:44 PM   #7
lol.... Oh well.
So... ah.... can you try to get me some LS2 Yukon coils? Seriously.
Old 11-23-2009, 03:54 PM   #8
So I had an emmisions test today :suspect:
I found a shop, not exactely local, about 85 miles away that was sympathetic to my needs. He said as long as he didn't have customers waiting for an emmisions test, I would be able to use the equipment in diagnostic mode with a tech present to do a little tuning and try to get her to pass.
So I spent ~3 hrs of the last few days welding in a new center section for my exhaust that consisted of a Magnaflow hi-flow cat and some other bits. I bought the one with the air injection port already welded so when I have to go back with a working air-pump, it's won't require me to take the exhaust off and weld stuff in, just plumb it up. I didn't replace the precilencer that I have now, I just built an entire new center section. The way my exhuast is set up, there is a flex pipe and the end of the DP with a 3" V-Band welded on. On the other side of the V-Band is a MagnaFlow 3" in 2x 2.5" out and a few bends heading off to the rear cans. Right around the axles there is a second V-Band on each side that seperates the mufflers from the presilencer or cat. I built a new section with the cat between the V-Bands. When I originally bought the pre-silencer, MagnaFlow offered the same case in with a cat installed. They have since stopped offering that so I had to buy a 3"-3" hi-flow cat and a 2x 2.5" - 3" Merge Collector as well as a few other pieces of piping. Either way all I need is my 7/16" subby racheting wrench and 5 minutes and I can swap the center sections out.
True to form, today is the deadline so I went up late this morning The tech backed the car in, no door dings this time, off to a good start.... although he did stall it FOUR times even after I warned him it was a grabby twin disc clutch, "eh, we deal with those all the time." It's a Rustang/Vette shop primarily. So we started her on the rollers with his foot on the gas and me working the MoTeC. Got her into 3rd gear, as opposed to first and started the sniffer. Ended up pulling about 20% fuel from 1500-2250rpms and right around the 40-60% effiecency mark (roughly the same in kpa) to acheive a L of ~.98. I generally have her running ~.9-.92 in that range.
Someone else showed for a test so we pulled my car out, I was done anyway, pulled a honduh in for the CT Emmisions test and that failed then pulled my car back in, again no door dings but one stall.
Here's what happened next -
This was done on regular 93 oct, Idemitsu PREMIX IN the tank mixed at about 1/2 oz/gal AND the OMP working as well. This is more oil than what is recc'd but I was doing some SEVERE back road jaunts yesterday with a few local rotorheads so I added a little extra lube love. No alcohol tricks, no crazy advanced timing, no pumping cubic acres of air into the exhaust, no air pump at all and BOTH tail-pipes being sniffed and she still passed. Who says you can't have a street/emmisions legal 400+ RWHP rotary???
Oh, and the engine survived this time with all her sideseals intack Coolant hit 188* and oil hit 170*, hood open, no fans though, but there was a garden hose present that I noticed JIC.
Old 11-23-2009, 04:07 PM   #9
FC3S Murray
frustrated!
FC3S Murray's Avatar
You crafty Son of a bitch!! Good job!
Same pig, new soul
Old 11-23-2009, 05:13 PM   #10
I hate you even more now!
Oh wait, I dont have emissions
Old 11-23-2009, 06:07 PM   #11
Nismo
400WHP or bust
Nismo's Avatar
Just an FYI Brian, you only have 11.6 HP, I feel lied too!!!
Old 11-23-2009, 10:33 PM   #12
Thanks Sean
(FL, VA, and all you other bastards with no Emissions )
Come to DGRRX and I'll show you what those 11.6 horses can do!
Old 11-23-2009, 10:47 PM   #13
Not all of VA is emissions free - but most is
I still have "visual" inspection so without a cat, they'd fail me...
Old 11-24-2009, 02:45 AM   #14
JShiz
ZOMG WTF BBQ!!!
JShiz's Avatar
this is for you
http://www.siliconeintakes.com/produ...24db21e1afda43
Old 11-24-2009, 04:29 AM   #15
Wait, how the hell does that work? Certain metro areas are still subject to emissions but if you live out in the sticks, pollute away?
Originally Posted by project86 View Post
thats about the only thing i like about MT. no emissions here. and when i move back to TN i wont have to worry either
How is that? I thought TN was one of the states? Or is becuase your car will be beyond the 25 yr mark? My FC only has 1 more test to pass 2 yrs from now, the FD though, needs another 5 tests... if it was running today... ugh. Knowing me though, I'll have her finishished when she only needs 1
Originally Posted by JShiz View Post
I wish it was that simple. The DSM guys all had those. Those fricken cars would pass a CT sniffer with no cat, they ran so clean.
