Old 08-29-2009, 02:51 PM   #1
Turbo II Rotor
Turbo II Rotor's Avatar
Turbo II Rotor is on a distinguished road
Cosmo fuel pump. I found that the short little piece of fuel line in the tank connecting the pump to the fittings ate itself, along with the sock being clogged again as well as the main filter. I grabbed my buddies full S4 TII assembly to snag a sock and that short little piece of fuel line from his.
Ugh, that little piece of hose took so long to put on too.
Turbo II Rotor is offline   Reply With Quote
Old 08-30-2009, 01:35 PM   #2
Originally Posted by TehMonkay View Post
Looks like you may wanna take you tank out and take it to be cleaned, then run all new stainless AN hardlines to and from the tank.
Sounds like it's worse than my car.
The tank is pretty damn clean and has been since I stole it from my buddy. The fuel lines I already replaced with -6AN stainless and I'm not going to be doing that again. I pulled EVERYTHING from the filler to the filter. I found a metric shitton of corrosion on the filler tube and spent a long time with a few scotch brite pads and assorted screwdrivers and picks and cleaned it out the best I could.
The tanks filler was painted on the inside, just the short little section and it was flaking so I scotchbrited that down and then flushed the tank until I could get no more contamanients out of it.
The filter I think I'm going to replace with a pysically larger one. I spent hours cleaning that filter and I'm not convinced that it's clean, or ever will be for that matter. It's fucking epoxy for crying out loud that plugged a 10 micron filter. I think it's fucked forever.
Yeah it was. My dumb ass had to cut the one that was already on there too. I've since chanced that out to a -6 coupler, then a -6 male to 1/4"npt and a 1/4" npt to 5/16" barb. That other fitting was for -6 so it really was the wrong size. Now when the pump sits in place it's about 1/4" below the barb fitting. Can't thank ya enough for your help with that Scott, hopefully next year all these stupid little problems will be gone and we can actually enjoy ourselves.
Old 08-28-2009, 10:01 PM   #3
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
Originally Posted by Duffman692002 View Post
He said 'should' EJ, damn... Give 'em a break, lololol.
No way, I'm the reason he gets stuff done so quick
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
Old 08-29-2009, 06:28 AM   #4
YAY!!!! for all nighters........... no wait.... that's not right.... BOOOOOOOOOOO
Off to KDR
Old 08-29-2009, 04:40 PM   #5
TehMonkay
Old 08-30-2009, 01:50 PM   #6
So yesterday @ KDR was............... interesting. Bill came up which was really cool and his FE put down some really nice numbers for a bone stock 8, I'll let him fill you in on the details as I was only there for one pull. In my sleep deprived state I got lost on the backroads and ended up driving through cornfields, litterally.
I am now referring to my Most Ungrateful Mistriss as a Dyno Queen. Why you ask? Because every time we go to the dyno, we strap her down and she just sits there, all day, on her thrown doing nothing.
So we strap her down and the conversation with Dave goes like this,
What do ya wanna do Bri?
Obligitory compression test of course.
You really wanna know?
I think so..... if somethings off I'd like to know before we chunk the motor.
Good point, ok lets see what we get.
Front rotor was perfect - 115 on all three faces. Rear was like 120, 120, 120, 120, 88, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 88, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 88, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 120, 125, 120, 120, 120, 120, 120, 120, 120, 120, 88. Sticking apex seal Not every revolution mind you, ever third or forth it would hang up just a touch and miss. The fear Dave had is the seal will get stuck out as it crosses the minor axis and shear off, chunking the entire rear. So we bullshat the rest of the day until it was time to leave, then Dave tells me,
Get this piece of shit outta my shop, I wanna go home and run my dozer So Bill and I left and had lunch and dealt with all the country bumkin stares and comments as two rotaries pulled into a very locals type place that Dave sent us to for food.
So now the plan is to pull the engine, clamp the int plate to the front plate so nothing shifts in the front, pull the rear rotor and find what we think is a sticking corner seal thats holding the Apex seal up. I do remember when I was clearancing the rotors that one corner seal wouldn't pop up ever time. I moved it to a different corner and the seal was fine, this tells me the recess in the rotor itself is a little off. So I grabbed a different corner seal and tried that. Better, but not perfect. So I worked that recess until I was happy. Apparently not enough. Oh well.... Bill made a good point, it's not a rebuild so we can't call it engine 5, we're calling it 4.5 Hopefully I'll get it done this week and I'll be back @ KDR next Sat
Old 08-30-2009, 03:06 PM   #7
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
Don't lie... you forgot the camcorder, made like 400hp, then were like "oh shit! Ejay demanded video..... um..... excuse....excuse..... uhhhh STUCK CORNER SEAL!"
3. ?????
4. PROFIT!
Old 08-30-2009, 03:12 PM   #8
need RX7
Clean S4 Nutswinger
need RX7's Avatar
FFFFUUUUUUU-
Good luck, good thing you found it before it went bad.
Old 08-30-2009, 03:19 PM   #9
I wish! Bill was all set with the camcorder than he put it down becuase comp tests are boring..... never picked it back up
Originally Posted by need RX7 View Post
FFFFUUUUUUU-
Thanks, yeah it is, still pisses me off though
Old 08-30-2009, 03:33 PM   #10
rotors are a test of patience and determination.
Old 08-30-2009, 03:55 PM   #11
There is no limit to my stubborness...... just ask any of my ex's
Old 08-30-2009, 04:02 PM   #12
i think i fall into the masochist category, myself.
Old 08-30-2009, 07:23 PM   #13
I want to know what I did to anger the rotor so
Old 08-30-2009, 08:06 PM   #14
Old 08-30-2009, 09:06 PM   #15
A good friend of mine has a TII that we're ground up restoring and dropping an LSx into it. I stole your avatar a while ago when I started an acct on V8RX7forum
