Needing a new tow rig.
This is real simple. Oil flows DOWN and back if your driving so if you crall under the car it will be easy to see where just look above the last drop you find till its dry theres your oil leak. ALL the oil will be in the pan when shut down so if it says full its FULL. after you changed the oil you ran the car for a minute right? and sinse there are only 3 oil related things you touch when changing oil LOOK there first. OIL DRAIN PLUG, OIL FILTER and FILL/DIPSTICK. if i remember the drain is passanger side? and easy to see if its leaking. the other two are driver side oil filter could hve cut or non seated o-ring. hell it could be your fill neck cracked and leaked oil down the block being it is plastic. when you were filling it.
seals dont just crap out all of a sudden unless its a APEX SEAL lol look at what you touched first! my 2c Z |
