Old 02-22-2009, 10:08 PM   #13
nissanconvert
nissanconvert is on a distinguished road
Originally Posted by Low Impedance View Post
that was one partially lucrative idea, running the water sprayer constantly. Also the idea of using a CO2 system was a possibility because it would leave no water on the track but i would have to see what the rate of flow is vs. size of bottle to see if it would last an entire run or not.
That particular system is high pressure, the idea being very very small droplet size. None of the water should make it to the track. A variation of the system was adapted as a through the filter auxiliary water injection sprayer- and the filter wasn't wet. I have a dirt cheap system with a boost switch and a windshield washer bag & pump. It's not nearly as efficient but my temps return to normal far faster than they did without.
nissanconvert is offline   Reply With Quote
