Old 02-12-2009, 10:51 PM   #1
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
FS: 90 Black on Black TII & 91 NA auto w/63k
I am selling both of my FC's in hopes of getting another fd. I feel both cars are excelent daily drivers. I will be happy to answer any questions about either car. I am willing to help with the delivery of either car and also feel both are ready to be driven home.
1990 TII $5,700
1000xx miles
Just put new samco black hoses on the radiator and the innercooler, replaced the cracked seats with seats that have no cracks and are soft after conditioned, The stock wornout speakers were replaced and I installed a new alpine headunit (9884). It has new wiper blades front and rear. Just installed was a new clutch master and slave.
All stock parts are included and can be installed if requested
This is info from previous owners thread(with a few amendments)
Specs:
Intake: 04/2008 Deleted Stock airbox, will give to buyer
New K&N Filter and custom mount for airflow meter
Exhaust: 03/2008 New Racing Beat SS 2.5” Downpipe, pre-silencer, gasket
Stock Y-Pipe and mufflers
Suspension: 03/2008 Used Koni Yellow Shocks in good condition
New Racing Beat red springs
New Right Lateral Link
Tires: 02/2008 New Sumitomo P225/50/R16 tires
Brakes: 04/2008 Deleted ABS system, will give to buyer
Installed Mazdatrix ABS delete kit, flushed system
Emissions: 03/2008 Deleted ACV and air pump, installed block-off plate and dual-pulley for the water pump. Note that this car has no catalytic converter now and will not pass emissions testing.
Ignition: 03/2008 New Spark Plugs and Wires.
Fuel System: 06/2008 New primary fuel rail, new (refurbished) fuel injectors, new fuel filter, cleaned gas tank and fuel pump
Misc:
New Mazdaspeed oil filler cap, new passenger side window open/close switch,
New Split Air Intake Hose. The entire fuel delivery system has been removed, cleaned, and replaced as needed. This car starts right up under any condition; hot, cold, etc. Vacuum system tight, turbo spools perfectly. All electrical works perfectly, including the sunroof.
The Bad:
1. Rust spots on the sunroof
2. Right window trim strip flaking off rubber coating
3. Needs new rear brake pads
4. Gas Filler Cover Plate bent (have replacement needs to be painted)
5. Spoiler has some cracks in it
6. passenger a pilliar trim cracked
History from previous (original and only other) owner.
She bought the car new in 1990, and generally kept it garaged. But some neighborhood kids vandalized it, pried open the gas filler cover, and poured in sugar. She had things fixed up, then sold it to me. This is why I paid Mike Lowe, of Lowe’s Automotive Performance (RX7 specialists), to go through the entire fuel system.
1991 N/A automatic $4000 obo
This car I found before the Black TII and I couldnt turn it down considering how low the mileage was and the fact that it was stock without a single modification.
specs: 63,0xx org. miles
red exterior with black leather interior
the car just recived new front and rear brake rotors, an auto transmission flush, and coolant flush.
The "bad" :
1: spoiler and moldings are slightly faded
2: drivers a pillar trim cracked
3: seats are cracked
4: sunroof has small rust bubbles on it
mazdadude7 is offline   Reply With Quote
