Old 01-30-2009, 08:20 PM   #24
Honestly, vac leaks are either there or they arent, cold or hot. The vac numbers sound low, which isnt good. Its hard to get accurate compression checks with a piston tester, but I'm thinking you may want to do another comprsesion test when the engine is hot and see...
coolant seal failure, egr block off, rtv, vacuum leak
