Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 01-22-2009, 09:25 PM   #11
RotaryWhat?
RotaryWhat?'s Avatar
RotaryWhat? is on a distinguished road
Regarding the premix tank design---I can't think of a filler/cap location better than what you pretty much have drawn up. Attached is a picture showing the routing of the IC piping (mine will be similar)----I think your tank will still fit. Perhaps you could cut off the top part of the tank on the drivers side just to make a little more clearance? I don't think it will affect the capacity much, and if you could run the sight line out of the front instead of top I think there would be enough room. What do you think?
Also, I wanted to make sure that your tank will have clearance for the steel braided oil metering lines around the water pump---it looks pretty close in some of your pictures.
RotaryWhat? is offline   Reply With Quote
