#20 | |
Non sequential can be proven to be a bad idea with the reading of dyno charts. Nonsequential gains a minimal amount of hp on the top end and the losses in torque and spool on the low end make the car technically slower than one with a functioning sequential system. You cant argue those points. There is some info for you. As for the 99 spec twins. They have something called an abradiable compressor housing. Which is actually just a plastic insert in the housing that the compressor wheel actually wears a groove into to increase the tolerances in the housing. The only benefit that has been reported by the 99 spec twins are a faster spool time and the obvious benefit of having brand new turbos. Otherwise the power increase comes from other modifications made to the rest of the power plant such as the efini y pipe and different engine management. Some of the internals of the 99 spec rotary engine are different as well. Namely the "bath tubs" on the rotors. Picking your turbo with spool times in mind is a great idea. Just make sure you dont listen to people who tell you that 380 is a reliable number to make on stock twins. Its just not. Low 300's are the maximum safe area for the stock twins. Any questions on my setup please feel free to pm me. --Hank Last edited by hsitko; 12-28-2008 at 05:11 PM. |
