#17 | |
Rotary since 1972
Outlet pressure 350~500 kPa (49.8~71.1lb/in2) Pressure reg no vac at control solinoid 260kPa - 36.97psi vac at 200kPa - 28.44psi injector volume 173+/-24cc/15sec. Don't know if that might help someone figure it out. Mazda doesn't give a fuel pump volume spec for the EFI cars as it does for carb models. I never checked what an unrestricted pump puts out on the se, Do know that it really makes one hell of a mess if you do forget to hook it back up. Since Mazda no longer sells the pump for the GSLSE the walpro seems to work alright on a flow ported motor and intake which passes IM240. Still working on my se although it does make some noise once and a while. Last edited by rx4ur7; 11-25-2008 at 03:48 PM. |
