Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 03-10-2008, 09:52 AM   #12
My5ABaby
My5ABaby's Avatar
Here's some reasons why some of the fuses could blow/keep blowing.
Main Fuse (80A):
Battery hooked up backwards
Alternator cable terminal end touching anything grounded or chaffing anywhere
Engine Fuse (15A):
Main Relay/ Circuit Opening Relay/Fuel Pump
(Wayne88N/A from RX7Club.com)
1) Disconnect the plug from the back of the alt
2) Disconnect the circuit opening relay (pull the plug)
3) Insert fuse. If it blows, you have a wiring problem in the alt voltage reg/excitation circuit wiring (I'd look near the plug for chaffing against the water pump housing or front housing), the power circuit wiring for the fuel pump/circuit opening relay, or the main relay (or wiring going to it) is bad.
- Isolate those three down to find the gremlin...
- If it doesn't blow, reconnect the alt back plug and try again. If it blows, your alt volt reg is bad.
- Disconnect the fuel pump plug at the left aft strut tower...
- Reconnect the circuit opening relay. It if blows now, you've got a short in the wiring to the fuel pump connector, or the
circuit opening relay...If it doesn't blow...
- Reconnect the fuel pump connector. If it blows now, you probably have a bad fuel pump.
EGI Comp (30A):
- Feeds all the solenoids on the rack and the two solenoids on the ACV.
- Look for a broken wire around the acv solenoids or a bare wire at one of the solenoids on the left of the engine.]
- Check the wiring bundle in back of the alternator, I had (and someone else I know) had this same issue and it was due to the following problem; There's a metal clip, used to hold the bundle in place that is connected to the back of the alternator pivot bolt. After years of vibration, this metal clip wears at the insulation and causes a short. For me, no wires were visible, but the insulation was worn enough to cause a problem. Simply wrapped the wiring bundle in a couple layers of electrical tape and removed the metal clip.
