Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > CJ-Motorsports
CJ-Motorsports Specialty fuel system products
Old 03-09-2008, 09:53 PM   #10
RXtacy
RXtacy's Avatar
From CJ-Motorsports website. List price is $315.
The rotary engine relies on a quality supply of fuel. Since it is sensitive to under-fueling, it is a good idea to upgrade to twin fuel pumps in your RX7 before running into starvation problems when tuning for high boost and horsepower.
The CJ Motorsports twin pump assembly is unmatched in quality and fit. You get a billet 6061 aluminum CNC machined flange with 3 bulkhead fittings that are -6 in size. Also included is a fuel safe 6-pin bulkhead electrical connector to safely and professional source power and ground for your pumps and fuel level sensor. Included are a pair of connectors and matching terminals that connect to this bulkhead on both the inside and outside of the flange for quick disconnect serviceability.
The pumps are supported by isolating plastic brackets with viton o-rings. This will keep the pumps quiet and not squeeze them together too tightly, distorting the internals.
You will be happy to find that this unit is available in 2 versions; twin walbros, or twin bosch. Use the corresponding ordering button for the version you prefer. Also, you may swap just the 2 brackets to change your fuel pump type later.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
