#18 |
with no vacuum leaks and stock ignition timing I could get my '86 to idle at about 300 rpm. My '91 will only go down to about 400 rpm with the idle screw all the way in (700 with 15 degree advance)
edit: If you get your ignition timing right, the car should rev ok when held flat on the floor (as long as AFM is functioning properly and TPS reads wide open). Vacuum leaks have little effect at WOT.
1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) Last edited by NoDOHC; 10-30-2008 at 10:49 PM. Reason: to make more helpful |
