My A-Spec 500R Kit Dyno Charts
Had my '93 tuned by Ray Wilson at PFSupercars last week. Very happy with the power numbers but the lag is pretty bad.
Tune was with 93 octane gas, Ray said I was making about 15HP / pound of boost. I've marked each graph at the point max boost was achieved (15.9lbs @ 5.6K rpm). On the road it seems more like 6K rpm until max boost though.... Mods include: - Tial 44mm WG w/ .9 bar spring - Greddy 3-row FMIC - 550s/1600s, Supra pump - a-spec long runner manifold Would be very interested to know from others with this kit how much boost they're running and what RPM it is reached at. I'll put some pics of the kit in the next post. |
Here's a few pics of my A-Spec 500R Kit pre-install...
wow thats awesome! i'm actually planning on buying the same kit, but their "500r-sp" kit instead.
#4 | |
- Kevin |
#5 | |
Rep Power: 21 ![]() |
Why are you getting full boost so late?
No idea, really wish I knew. I wanted to see if you folks had any ideas?
Someone was looking at it Saturday at the Speed for Sale shootout and thought the manifold looked pretty restrictive.... Again, I'm happy with the power, just wish it was more responsive. |
The car pulls great up top, but it should be seeing 15lbs by around 42-4500 not around 5300 rpms.
Here are some pics of Kevin's car, one of the best looking fds in the country in my opinion.
David Jerome Broker for Speed For Sale LLC (David@SpeedForSale.com) (Pre-owned RX7/sports car sales & new parts sales/installs/tuning) ![]() PM me about low priced, high quality port work
#8 | |
holy giant turbo of immensity! That thing is HUGE!
Any porting done to the motor? Is it possible the manifold isn't working with the exhaust flow (if motor is ported)? Looks like the mani starts off wide, then gets narrow and then wide again, right by where your hand is. I really don't know a thing about the A-spec manifolds though. Any more info? Worse case scenario you add a bit of nitrous to get the car going?
![]() Last edited by Phoenix7; 10-27-2008 at 01:17 PM. |
#9 | |
#10 |
crash auto?fix auto
Porting on the engine?
Exhaust size/configuration? (any cats?) |
#11 |
#12 | |
Sweet pics David thanks! The compressor does look big in that one, lulz.
#13 | ||
#14 |
The Judge
The boost curve is sloppy like your EBC is not functioning too well or not properly hooked up. It spikes and then drops off erraticaly.
Mine did that when I first hooked it up. Then I tried hooking my EBC differently than the manual showed. If you use the turbo outlet as your boost source for both the WG and EBC, then it senses a higher base pressure than the controlled pressure source. This is caused by the pressure drop in the IC. I take my pressure source from my Greddy TB elbow and that "Ts" into the WG side and WG solenoid input. The IC also acts like a filter to smooth out fluctuations. This made a great improvement in my boost control. You might also need to experiment with the GAIN to obtain the quickest spoolup that does not either cause spiking or boost start to increase. You max HP was produced at 15 psi boost. Thus if it stayed at 16psi, you would have made maybe another 15 HP. "Ray said I was making about 15HP / pound of boost." Last edited by cewrx7r1; 10-27-2008 at 10:27 PM. |
#15 | |
good to know
| Tags |
| 500r, 500rsp, a-spec |
