Old 10-04-2008, 04:21 PM   #7
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
Be carefull. IIRC both the high and low Imp injectors show the same part # on the side. You can tell them apart by the connector. The High Imp injectors have an offset "key" and the low Imp have a centered key. Your 88 should have High imp. injectors. Also, I don't think you can get an "injector cleaning kit" although, I could be wrong. If you wanted to clean them yourself you would probably have to let them soak in a vat of carb cleaner or something overnight. Then you would be left trying to source the pintle caps, grommets, filter baskets, & O-rings. I would wind up costing you more to get the parts than it would if you sent them out to be cleaned. (I looked when I went through this)
1988 GXL
