Old 03-06-2008, 11:17 PM   #1
Brent
Sua Sponte
Brent's Avatar
93 FD Owners with peeling interior, don't want to buy new panels? Look inside!!
This is a little trick that I figured out thanks to Scott Fleming(Power Hungry on other forums) when he purchased an FD from me in 2002. Basically, you are stripping the top layer that peels off the panel to reveal a very smooth shiney finish(what appears to be the gel coating). I have done this to several interior panels over the year by heating the panel up lightly with a heat gun, then using goof off with a rag to remove the peeling layer. Which takes alot of time, but IMO, is worth it once it's all finished.
Recently, technomentor discovered a new way to do this while removing tint. Here is a quick how to.
This process can be done for the cost of under $10 and a few hours.
What you need:
-water
-ammonia(you can purchase at Wal Mart for a couple of bucks)
-latex or protective gloves
-ventalation mask
-outdoor area
*Make sure you have your gloves and mask on at all times*
1. Remove the interior panel you will be stripping(ie door panel trim, gauge hood, A/C panel, or shifter panel). You can do it without removing them, but you need to tape everything around it up. Even so, I still do not reccommend doing it with the piece still installed in the car.
2. Next take appoximately 1oz of ammonia and pour it into a 20oz bottle of water. A normal aquafina or whatever water bottle will work fine. Put the cap back on, and mix it up a bit.
3. If you have a heat gun available, heat the panel up lightly to help make the peeling layer and adhesive come off easier. If you do not have one, do not worry about this step.
4. Take a cloth and saturate the panel with the ammonia water solution and lightly rub the panel. If it does not begin to come off, let the solution sit on the panel for approximately 5 minutes or you can rub harder. However, rubbing harder can put fine scratches on the panel(this has only happened when I have used a scotch brite pad). I also normally add a little more ammonia to the water. You will have to play with this and see what works best for you. As always, it is best to start off using the base 1 oz of ammonia for 20oz of water and add more as necessary. WARNING: Using too much ammonia or heat can melt, deform, or discolor the panel. Although this has never happened to me, I would reccommend trying this method out on a broken interior panel you may have laying around.
5. Clean off interior panel throughly with water. Once it is nice and clean, I normally put a little armor-all on it. It doesn't really make it shine anymore, but it never hurts anything. The finished product looks like this:
Door Trim:
Shifter Panel:
