Old 09-16-2008, 11:24 PM   #4
cewrx7r1
The Judge
Originally Posted by GreatShamanGT View Post
Do I need the Fuel Injector Atomization lines? I don't have any bungs on my intercooler piping. Should I get those on there?
The fuel atom. line is best to keep it. Tap the turbo compressor outlet and run a hose from there to the pipe on the LIM. This line has two uses. It allows more idle air without having to open the TB as much, and it helps idle fuel mixing due to the direct extra air flow right at the injector outlets.
The only IC pipe bung you need is for the BOV and have it between the IC and TB.
Best place for the EBC boost pressure is from the TB elbow. If a Greddy, tap and thread it at a convient location.
