#1 | |
Rep Power: 21 ![]() |
I always throw in the "Check your main relay" advice.
Check your CAS (Crank Angle Sensor) and make sure everything is plugged in/perfect. What have you done so far? Check out this thread (READ IT ALL) and then check out the post about the TPS and ECU Code tester (post #7): http://rotarycarclub.com/showthread.php?t=1790 This one also has a GREAT Article on the FC's Ignitions systems.
![]() Last edited by Phoenix7; 09-09-2008 at 07:16 PM. |
