Old 04-16-2017, 08:43 PM   #39
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
So its looking like the rx4 isn't going to make it to dgrr. Having some issue with the oil pressure. When it's cold it works great 100psi+ of oil pressure at 3000rpm. When engine temp hits just below 150 degrees Fahrenheit oil pressure randomly drops almost to nothing for a split second and then slowly comes back up. After that I can only manage about 85 to 90 psi max oil pressure. I've replaced the sender for my gauge, front cover o ring, rear oil regulator (fd regulator), front regulator spring shimmed 1/8", and oil cooler thermostat and spring. Guess the FC will make the trip instead this year.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
