Old 07-11-2016, 08:41 AM   #11
Originally Posted by Fendamonky View Post
I'd say pull the plugs to see if they're damp. You can crank the engine with the plugs out and, I believe, the EGI fuse removed to deflood the engine. Or, I'm fairly certain if you just put the gas pedal ALL the way down and crank it should also cut the fuel. Doing that a few times should clear out any flooding.
Not true. Most of the time with questionable plugs they need to be pulled and cleaned, and the engine cranked over for 20-30 seconds without the starter to really clear it out
If the car won't start after it's been deflooded and has new plugs in than try the push start.. If the engine starts but runs rough as hell and scrapey, shut it off IMMEDIATELY, and take that shit back to the dealership for either a refund or a $5k discount, because that's what the rebuild will likely cost you...
I've yet to see a renni fail from an oil related problem. Most of them just get tired sticky and cranky and loose compression
Originally Posted by JL1RX7 View Post
I would change everything. With that many miles on the RENI I would bet it's blown. Seeing oil on the front isn't a good sign. 8's have had a problem with corrosion on the oil cooler lines and splitting. So it's a good bet that's happened if it's been a northern car all its life.
Blown is a little harsh... lets not forget FrankenB's donor. Nothing was broken on that engine, just a dirty TB, and MAF sensor, and the internals were all sticky and pissed off.... but nothing was blown
new plugs and especially new coils.
Werd..... new coils... I don't even want to think about how many engines were replaced under warranty because of faulty coils.
A fully charged battery, real 91 or so gas fill to at least half a tank and try to start her.
91 gas? What is that phaggotry
Things to check/clean the SSV and the MAP sensor. Both are known to cause hard starting issues.
And TB, don't forget the TB
[QUOTE=JL1RX7;332832]
Also be careful of what you read on eight club. Lots of good info on there. But lots of armchair bullshit with it. Follow the tech stuff on how to pull it apart. The rest is mostly opinions. So you generally get one piece of good info in a thread with rest either wrong or lies. It can be difficult to figure out which is which.
That....
Possible, but usually that's lower on the block. Either the injectors are clogged and the OMP kept pumping or the SSV did something. But around the coils no oil lines are close. Fill tube and oil filter are further back.
Fill tube and oil filter tend to do alot of leaking though if someone is trying to fill the engine in the hurry
Originally Posted by RotaryBC View Post
Removed the coils, wires and plugs
Plugs:
Top Front
Lower Front
Top Rear
Lower Rear
Wires To:
Top Front
Lower Front
Top Rear
Lower Rear
Coils tested good
Secondary shutter valve...are you kidding me?
The tech manual starts at “Remove the front bumper
I thought it was bad when it said “Drain the coolant
Did see the three valves...the bottom one had oil on it
Tell me what you think about the plugs
Sooooo much wrong there... especially with remove front bumper.
OK.... soooooo look.... You've really not done much here to troubleshoot anything. You pulled the plugs... now compression test it.
Put the #2 plugs back in, pull th TB off, pull the EGI fuse and crank the engine over and LISTEN very carefully. Every compression stroke should should sound the same and be the same time apart. Does it?
Yes - Install the compression tested with the schrader valve and crank for 15 seconds. Report the numbers
No - I hear a psh whooo whoo psh. Engine Blown. I give this a 10% possibility
Repeat for the rear rotor.
Next step, install ALL NEW PLUGS & WIRES & COILS
Next, drain the gas
Next, Add fresh gas!
Next, try to start it with the key.
If that doesn't work, pull start.
