Old 09-12-2017, 04:49 PM   #1
FC Zach
FC Zach's Avatar
But it's hub-centric. . .
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 09-12-2017, 04:49 PM   #2
FC Zach
FC Zach's Avatar
And with tapered lugs. .
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 09-12-2017, 04:59 PM   #3
Brilliant!
Old 09-12-2017, 11:29 PM   #4
FC Zach
FC Zach's Avatar
Brilliant!
I was more or less saying I didn't see the issue, in a smart alec kind of way But I get your point, especially if the wheels are aftermarket without centering rings and especially with flanged seat lug nuts.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 09-13-2017, 10:31 AM   #5
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Who's alec? He doesn't sound very smart...
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 09-15-2017, 10:29 AM   #6
A little leak goes a long way, and the level might not be affected enough. It is something that should be done, and takes 2 seconds. lol
Old 09-15-2017, 10:42 AM   #7
project86
project86's Avatar
clearly... which is why I said "there is fluid".
'90 GTUs
'10 Toyota Prius
Old 09-15-2017, 10:52 AM   #8
You weren't specific!! Thought you meant there is fluid in the MC reservoir. Lol.
If there is fluid under the slave cylinder plunger boot, replace it and add an SS clutch line if you don't already have one. They're cheap.
Old 09-15-2017, 10:58 AM   #9
project86
project86's Avatar
Oh I think I misunderstood what you were saying to check. I actually have a new slate and an ss line in my mazdatrix cart. Waiting to hear back from Adler about a flywheel and counter weight.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 09:45 AM   #10
project86
project86's Avatar
I think I may have mentioned that I developed an idle surge. I initially had the screw in the top of the TB backed all the way out after the emissions removal and it held around 900RPM.
Lately its been idling around 1500 and surging to 2000 intermittently. So I was reading on the other forum about it and found one thing that said adjust the screw so I screwed it all the way down and it brought it back to around 900-1000. After I started driving it the idle jumped back up to 1500 but didn't surge any more and then settled back down to 900. Still no surge so thats good.
Do you think by BAC could be bad? I know i dont "need" it but it does help with idle speed. I suppose I could unplug it and see how the car responds.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 09:55 AM   #11
infernosg
IT'S ALIVE!
infernosg's Avatar
There's a procedure for adjusting this screw in the FSM. IIRC, while idling and warmed up you have to ground one of the pins in the green check connector located elsewhere in the engine bay and then adjust the screw so the TPS voltage is within a certain range.
EDIT: In the '89 FSM it's in section F1. Pages F1-15 and 16 cover idle adjustment, pages F1-40 and 41 cover idle control and checking the BAC, and page F1-83 covers checking the TPS. Found here: http://www.wright-here.net/files/man...mission_NA.pdf
Old 09-21-2017, 09:59 AM   #12
project86
project86's Avatar
It wasn't the TPS I was messing with. That we got adjusted correctly a while ago. I'm referring to the "idle screw" on top of the throttle body/UIM.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 10:04 AM   #13
infernosg
IT'S ALIVE!
infernosg's Avatar
Yeah, there's some other crap you have to do when adjusting idle. You're not supposed to just turn the screw like with a carb. I updated my post above with info from the FSM.
Old 09-21-2017, 10:08 AM   #14
project86
project86's Avatar
Kyle, that's what he's taking about. . There's more to it than just turning the screw.
Check your manual.
Oh ok. I gotcha. I'll have another look then. It seems that it did make some difference though.
'90 GTUs
'10 Toyota Prius
Old 09-21-2017, 10:00 AM   #15
FC Zach
FC Zach's Avatar
^ Yep, you can't just turn the screw one way or the other without making the connection on the test connector.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
