Don Mega
There is some real dumb and wrong assumptions state above ^
The side seal is NOT constantly forced to one side!@ IF it were it would never wear a path into BOTH corner plugs as it does in reality! A true ZERO BLOW BY design like I have made needs to be recessed into both corner plugs and not some ghetto cut off wheel doing a straight edge cut leaving a sharp edge too! that will not only seal like total crap but cause a very large stress raiser in the corner plugs = very poor idea. If you look at the rotor path you will see the side seal rocks back and forth in the side seal groove on each minor dimension of the rotor housing points, thus it slams from one side to the other in the side seal groove! it needs to be recessed into BOTH, so not only is the clearance NOT zero as in the un thought out claims by others who have butchered this mod, but its also not the correct way to do this either as shown above. Here is how its done right! below. This to work properly needs a bespoke material side seal and corner seal, as the stock parts are failure prone as is. There is clearance to all parts! and needs to be done by not an engine builder wannabe but by toolmaker/fitter/turner who have precision parts fitting qualifications and experience, NOT GOOGLED!@ ZERO BLOW BY RICE RACING
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by Barry Bordes; 03-09-2016 at 11:29 AM. |
