Old 07-03-2008, 10:13 AM   #2
with the motor pulled i started to degrease and scrub it clean. Once that fiasco was done, i pained the irons with ceramic spray paint for some visual appeal.
I also swapped out the GSL-SE front struts i had. Already have Eibach springs and some Adjust. illumnias.
I also am using a stock replacement clutch and pressure plate. The 1982 has the "light weight" flywheel, so the pressure plate is different than other years. Napa "zoom (valeo)" clutch only set me back about 130 dollars and came with the everything, including the alignment tool and throwout bearing and grease.
For the intake manifold, i splurged and got the Atkins rotary side draft manifold. Its a nice piece, but the ports need some reworking.
I also purchased a nice set of Suspension Techniques sway bars from Summit Racing. Its nice having them only about 20 minutes away. Installation for the front one sucks, to be plain. The rear is too bad. Just keep your hardware from the originals.
Once that was installed i settled the engine and transmission back into the car.
