tumor-syphilis-itis-osis
Just pointing out this info is amazing! its freaking sweet to just be able to find exactly what I'm looking for without digging through the mounds of rx7 club's post
82 300d 82 Gsl 84 b2200 Diesel 88 gxl |
#2 | |
learning
Rep Power: 21 ![]() |
sounds like you just need a shop manual with the schematics and im not clear on the air intake hose thing.
Location: hi-tech zone of Zhengzhou, Henan province, China.
#5 | |
die spambot diiiieeeeeeeeeee!
![]() www.rx7club.com.ar RX-7 Forum in Spanish I make custom decals. Yes, you can ask me |
so any thoughts on the value to a set of 79 limited wheels?
Rotary since 1972
Redline Water Wetter is safe for rotaries
I finally read parts of your informational thread. Over all excellent for documented information.
I do take exception with: Q: Can i lower my coolant temps with additives? A: A few small studies have shown that Redline Water Wetter, and the like, are corrosive to coolant seals and are advised against. Redline being the worst. Its recommend to aviod their use and if you do, flush it out as soon as possible. (provided by TitaniumTT) Do know know which scientific studies you have access to. I have been using Redline Water Wetter since it was introduced back in the 80's. Use it in all client vehicles, race vehicles (from IT stock motors to full Bridge GT motors), Generators, AC, with no problems that could be related in anyway to water wetter. When it was first introduced it did not have the protection for aluminum, and they recommended that some, at least 5% glycol be used in motors that contained aluminum parts. The product has contained aluminum protection for well over 20 years. Redline worked with Mazda to formulate chemical products that are safe to use in the Mazda rotary. Unfortunately they still could not come up with a synthetic that could be used in meter system vehicles. I continue to use it and recommend that any vehicle that is exposed to or will be used in extreme conditions use it. Also recommend that the more extreme means to change oil and coolant more often. I change the coolant in my clients vehicles every 3 years or 30K miles, max, as per Mazda service schedule. My experience is that most coolant related failures were due to either tap water, lack of service, incorrect mixtures, repairs or odd ball chemicals introduced. These generally lead to inevitable overheating. A couple were related to "improved cooling" modifications incorrectly done to housings. Tap water failures were actual housing failure due to corrosion. Otherwise good work. |
Can we talk a little more about simple spring/strut combos v. coil over setups? I have an 85 1st gen and she is tilting in the back (which I think may have compressed the brake line, no bueno). I took the wheel off and jacked it up, nothing is visibly broken, but it's getting a little crusty and I was considering replacing the shocks and either the coils or looking at a simple spring/strut combo. I have read through the manual and see how to make the swap, but in shopping for parts (the readily available ones sitting at autozone of somewhere of the like) I see that shocks are easy to find, but coils are not, would it be easier if I looked for the spring/strut combo?
I drive the car as a daily driver and with less than 60k original miles I would like to continue to do so for a while, so I am considering replacing shocks + coil or coil/strut combo in at least the rear of the car, perhaps front and rear. I 'think' I understand how to make the repair, but I would love some advise on solid parts suitable for everyday driving, and maybe not a million bucks ![]() Thanks, Sarah |
#9 | |
Rep Power: 22 ![]() |
For a strut/coil combo you have a few choices. You can get some Tokico's or KYB's. There are more expensive stut/shocks out there, but those will do fine for what you want. Racing Beat makes some excellent springs for what you want as well. But, for all your first gen needs, contact Billy at RESpeed.
#10 |
Thank you and I wont be offended if you delete my question and your response, could it maybe be split into a new thread?
I might have some more questions
#11 |
I think if a Mod were to see it, they might be able to help you out with that. Or just copy and paste to a new thread in the first gen tech section!
#12 |
Rep Power: 10 ![]() |
Whizbang. I don't remember if I asked this yet so here goes. I'm tearing down my 12A. Where can you point me for info on how to properly do the ports? It'll be my first time and I don't want to grind away too much. Only looking for around 20-30 hp. More would be nice but my FB will be daily driven, with aircon, in hot and heavy stop and go traffic, so I need reliability. I'm going to put headers and I've already got instructions on how to mod the Nikki. Any help as to where there are any instructions, would be helpful. TIA.
