Old 05-18-2015, 09:10 AM   #11
RXtacy
RXtacy's Avatar
That's actually good news - the engine dying intermittently at random sounds spark/electrical related to me. Chances are it does NOT need a rebuild yet; get the electrical gremlins exorcised and it will run/last a long time, even with low compression.
You didn't mention it, but first thing I would do is verify the alternator is working properly. Sometimes we get lucky and it's the easy fix.
I'm not too familiar with the RX8's, but I recall hearing somewhere on here that they are known to have issues with the coils/ignitors going bad, and I want to say there was a TSB/part # change to deal with that. A failing coil would cause your engine to die at random. Someone else more knowlegable about the RX8's can probably elaborate.
The coils on the 8 are garbage. They seem to last ~40k miles if that. If that car has the original coils they DEFINITELY need to be replaced. I would also have someone verify that you got the correct spark plugs from the mechanic.
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
