| Fabrication Show off the parts that you've built from scratch or highly modified |
#5 | |
Don Mega
I love pro harnesses, but are they needed? my view is no. Here is an example of doing up a pretty simple adaption harness that plugged into the normal loom on a FD3S. None of this is hard, but if you dont have the correct crimpers and plugs (DT series minimum) then you are pretty much wasting your time and better to leave it to a 'professional' Same if you cant read a wiring diagram or fault find. In this below instal for example there was a factory printing fault for one wire in the harness from Dynatek! this does happen and you need to be on it to find these kinds of errors and they do and can happen, if you will be making mistakes of your own due to lack of attention or poor equipment in construction then please get someone else to make it for you. Pics. Bit of background for people, I developed COP systems for the 13B-REW many years ago, field proven, this is one of my old systems below (CDI set up) ![]() ![]() ![]() ![]() ![]() ![]()
