Old 04-15-2015, 07:10 AM   #10
C. Ludwig
Rotary Masochist
What is the trigger since last home value while cranking. Should be 30 at all times with the Renesis wheel. If it's not 30, you have a trigger issue. Contact me if that's the case.
How are you checking for spark? Timing light or actually inserting a plug in a wire, grounding it, and visually confirming spark? Timing lights are finicky and may or may not strobe consistently. Visually verify spark with a plug.
Are the plugs in the engine fouled? If they are, you may not get a light strobe and it certainly won't start.
I told Jacob to space the sensor at .040". That should be good but confirm that with FFE. Their kits are pretty darn consistent and you shouldn't need to shim it.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
