| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
#11 |
Rep Power: 22 ![]() |
Did some work today, with some much needed help from Charles.
-Cleaned up the engine harness. Now there is only about 5 or 6 wires left. -Wired up the electronic dizzy and coils -Wired up the S4 alternator -front clip back on -fuel pump and lines installed We put power to it for the first time in at least 16 years. Amazingly, nearly everything works. Here's a list of what still needs to be done. -figure out why I have no brake lights -figure out why the wipers/washer doesn't work -bleed clutch -fill rear end -fill trans -fill oil -fill coolant -clean tank (happening Sunday) -fix oil leak at oil cooler thermostat -figure out why driver side mirror doesn't work Should be all buttoned up this weekend. Knock on wood.
