Closed Thread
Old 02-19-2015, 06:25 PM   #1
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
Personally I would get the clutch fixed and go from there. The throw out bearing fits around the input shaft and if it's bad enough it could be causing the noise or it may be loose pressure plate bolts. Eliminate anything in the clutch assembly first since you know that you need to do it anyway.
GySgtFrank is offline
Closed Thread
