Old 02-19-2015, 05:03 PM   #3
bert1584
bert1584 is on a distinguished road
Originally Posted by FerociousP View Post
Does the noise change on accel vs decel when revving?
Is the noise completely RPM based? or does it lag behind the RPMs a bit?
Does the noise change when you depress the clutch pedal?
I saw you put your finger on the SSV actuator, which is a common-ish issue that you may have seen on youtube vids. Have you been able to move the actuator to determine that isn't the culprit?
its linear to RPM, so I feel its something rotational orientated - no it does not lag behind.
No the noise does not change with clutch pedal - I understand there are various clutch components that disengage on clutch press, does the throw out bearing still sit between the drive shaft and the input shaft?
the linkage on the SSV is sound and the linkage is free moving.
thanks
bert1584 is offline
