Old 02-03-2015, 08:13 PM   #11
My situation is a little different...mine is an FD, dual oil coolers, VMIC and in Colorado LOL. Very dry climate, a little less air density at 6000ft, and summer days are usually between 70-90F, sometimes 100F, and winter days are between 20-60F with the occasional 80F day.
I think even without ducting my coolant is around 180F and oil around 130F while driving in the summer, and in the winter I've seen my coolant at 165F and the oil at 109F. My water temp sensor is behind the thermostat, which should be the hottest point, and the oil temp sensor is at the filter, so that one is going to read cold anyway. Granted you have a different setup, but still something to think about. It's better to err on the side of caution though, and if you need to you can go back and block some like you said. My buddy has a hard time cooling his FC down too.
