Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 01-31-2015, 11:05 AM   #11
project86
Can't.Make.Up.My.Mind.
project86's Avatar
The CDI box sends the DON MEGA high voltage to the low resistance CDI specific coils, the coils act as a step up transformer amplifying the voltage to INSANE levels. This process is super fast!... NOTE: it still takes time to build up the 'power' in the Capacitors and this is why even with multi channel boxes you need a certain minimum time between firing events to make the full rated capacity of that specific CDI box. For the M&W rotary box it can only do this on a sequential 4 channel ECU sending even spaced spark events out of the ECU (IE Apexi PFC does not do this on Leading plugs).
It IGN-1A uses inductance and takes time to build up the primary side voltage and current to a level that is acceptable enough, then as this field collapses it induces a secondary high voltage through magnetic inductance in the secondary winding of the coil, its a slow ass process, that is very dependent on 'dwell' or charge time. IF you don't have enough time to build up the charge then the c-u-n-t-s have very low power and will misfire, so cant be used on wasted spark engines (OEM and PFC), and they always struggle at high RPM due to the proportional loss of dwell time available to build up sufficient energy through this slow ass process...... this is why the c-u-n-t-s are shit on 2 stroke / WANKEL high rev applications as there is such low time between firing events ........... hope this makes sense?
Yes.. so its for speed and strength of the spark the coil is giving. So it would work fine with out the CDI box if it was run on a standalone system like Haltech?
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
