#10 | |
Don Mega
If I were Adobe I should charge around $20,000 for this ![]() But seriously I hope it to be in 100's range rather than 1000's cause otherwise I myself will run high tension leads or rip it all out and put in a boat anchor engine haha.On the 12A front: * COP Adaptors are universal (fit anything) ![]() * Engine bracket needs redesign per engine * Coil spacer brackets need adjustment to suit spark plug spacing in X & Y dimensions ![]() Would have to design an engine bracket mount that uses the bottom large hole in the center plate ![]() Best to put a 13B-REW in it ![]()
